| is this carb issue repairable? https://slantsix.org/forum/viewtopic.php?t=45966 |
| Author: | Philip's66 [ Mon Aug 15, 2011 2:23 pm ] |
You may be able to retap the threads. Use the correct size tap and carefully chase the threads. Use a bottoming tap. It will be flat on the end not pointed. You can grind the tip down on a fluted tap. be carefully not to force tap in . This may repair the damaged threads ,if they are not too bad.. If not try putting some JB weld in the damaged threads and retap. May be easier to go to next size larger screw to repair. Go slow when retaping threads. |
| Author: | USAJon [ Mon Aug 15, 2011 8:36 pm ] |
well, being inside the float area, I would wonder if that would work. |
| Author: | Aggressive Ted [ Tue Aug 16, 2011 11:56 am ] |
Yes, I have done it...and am running the carb every day. |
