| Heater Delete https://slantsix.org/forum/viewtopic.php?t=45978 |
| Author: | raPoM [ Tue Aug 16, 2011 9:45 am ] |
| Post subject: | Heater Delete |
What are you racers doing with the heater hose outlet/inlet on the water pump when you go heater delete? Anyone using caps? If so what are you using? |
| Author: | Doc [ Tue Aug 16, 2011 10:05 am ] |
I tap the hole and install a pipe plug. (upper pump in the photo below) Remove the hose bib from the head and put a pipe plug in that also. Keep the by-pass hose functional. DD
| Author: | raPoM [ Tue Aug 16, 2011 10:08 am ] |
Thanks Doc |
| Author: | Doc [ Tue Aug 16, 2011 10:23 am ] |
Off-hand... 1/4 NPT for the water pump bib. I use a tapered grinding burr to give the hole a little cone shape before tapping. Be careful with the die cast aluminum pumps, it is easy to crack / split the bib. (try your tapping process on a junk pump first, to get a good "feel" for it) DD |
| Author: | Shaker223 [ Tue Aug 16, 2011 10:46 am ] |
Using it to cool my turbo!!!! |
| Author: | raPoM [ Tue Aug 16, 2011 10:54 am ] |
Quote: Using it to cool my turbo!!!!
Oooohh! I didnt think about that. I plan on running a turbo,thats a good idea!
