Riddle me this
https://slantsix.org/forum/viewtopic.php?t=45988
Author:  Nongan [ Wed Aug 17, 2011 3:05 pm ]
Post subject:  Riddle me this
Ok so I have a factory peg leg 7 1/4 rear end in my dart. Well the other day I was leaving my driveway which is gravel and I accidentally gave it too much gas and did a quick burnout before backing off the gas but I looked behind me and there were 2 lines of fresh kicked away gravel, can someone explain to me how or why this would happen? Right after it happened I jacked my rear back up to make sure I dont have sure grip and the tires turned opposite directions. I've heard that if the sure grip unit is worn that it will act like a peg leg. Is this just total bs? Should I just take off the inspection cover?
Thanks,
Seth
Author:  Philip's66 [ Wed Aug 17, 2011 3:29 pm ]
I have heard/seen this happen just before a dif. went bad. Everything loose& worn out started acting like a posi unit then it went BOOM!!!
With it being in dirt everything mat be okay. Listen and see if you hear gear whine and other noises. 7 1/4 is a weak rear end. Mine exploded a while back and I am looking to rebuild it.Started whining spider gears went out.
Author:  Nongan [ Wed Aug 17, 2011 3:31 pm ]
Mine ocassionally cluncks super loud on the 2-3 shift with no gas. It scares my friends some times :) maybe I'll pull the inspection cover and see if there is a nice amount of shavings or broken teeth in there.
Author:  slantzilla [ Wed Aug 17, 2011 4:25 pm ]
An open diff will often spin both wheels where traction is limited.
The one in my Duster would spin both in the water at the dragstrip.
Never went BOOM! either. :lol:
Author:  Philip's66 [ Wed Aug 17, 2011 5:29 pm ]
Interesting! I actually learned something new!That's why I like this forum so much- all of the Experience we have is helpful to some one else. [img] :D
Author:  Nongan [ Wed Aug 17, 2011 6:45 pm ]
Maybe we can figure out this noise http://www.youtube.com/watch?v=THvge7qkYiI at 0:04 it makes a faint whining noise. Maybe that could be it? I noticed that my rear end had a lot of slop in it also.
