It is currently Sat Jun 20, 2026 10:49 pm
 Post subject: 904 Tranny Probs
PostPosted: Fri Dec 06, 2002 8:19 pm
In my Volare's 904 Transmission, it will go in park, but the engine will not rev up because it is in gear but the parking pin is in so it wont move, and when i put it in Reverse the wheels lock up, i am guessing reverse is antoganizing drive and not going anywhere, and than Neutral is Drive 1, and Than all other Drive Gears work. What is the prob and is it easy to fix?
Mike
1964 Dodge D100 w/318 from 78 Aspen (63 Cab with 64 Frame with 16 rims) Cleck out my webpage and see it
1975 Plymouth Valiant 4 door Custom w/no engine. Its the parts car
1977 Plymouth Volare 4 door Station Wagon w/225
PostPosted: Sun Dec 08, 2002 2:50 pm
It sounds to me like there's a problem in the shifter linkage. I'm not too familiar with 904s though, so I could be wrong.
PostPosted: Sun Dec 08, 2002 4:57 pm
Online
I'd guess that you have a clutch welded up in the trans. :shock:
