It is currently Tue May 12, 2026 10:55 pm
PostPosted: Thu Aug 25, 2011 5:09 pm
Well, I finally have a job now and I'm going to start sometime next week after a year an a half job search with no calls or interviews, thank goodness.
Today was the first day of my senior year in high school and because I'm going to school in Burke County, the only county in NC that I'm aware has this graduation requirement, I have to do a senior project. You write a paper, do a project and make a speech. I have to pick a mentor for the project portion and yada yada. But I have a two barrel and an intake to put on the car someday and I'd like some headers. I don't know how to weld but I'm confident I peice together a set of two piece headers as I was in drafting last year and I acceled so fast in there I actually took measurements off my two barrel intake during my freetime in class to make a three barrel intake. I've pieced together quite alot of things in my time working at my best friend's dad's body shop so I'm good at the assembly. Well I figure why not have my friend's dad teach me to weld and set me free on it.
I know I need a header flange if there is a good one out there or I can make one myself with a metal plate. I need to know what kind of metal plate, I do believe I'd need carbon steel right? That's what the make exhaust pipes out of if I'm not mistaken. How thick should the plate be? On the actual exaust tubes for the headers. how big should the primary tubes be? I wanna use two inch collectors and run them open because my car is so old, I don't have to get it inspected. No noise ordinances either. Is there anything I'm forgetting to ask? Am I making this project sound easier in my head than it actually will be?
I'll probably have more questions shortly after I post this. And by the way, here's that manifold.
On a side note, some of looks you get when you carry around a cast Iron two barrel intake in school, you get some funny looks and questions.
PostPosted: Thu Aug 25, 2011 5:20 pm
Flanges are available on ebay.
$31
http://cgi.ebay.com/ebaymotors/Slant-6- ... 4aae257b85
11.02 @ 120.56
Chassis dyno
PostPosted: Thu Aug 25, 2011 5:21 pm
Sweet! Thanks. Why didn't i think of ebag?
PostPosted: Thu Aug 25, 2011 6:18 pm
Great project! Best wishes for a good result!
Will it be possible to run the engine on a dyno afterwards?
Olaf.
Aspenized
PostPosted: Thu Aug 25, 2011 7:03 pm
Sweet design! Let us know if you do put it on and how good it works. You may get some orders :lol:
Cody
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
PostPosted: Thu Aug 25, 2011 7:10 pm
6 Pack Dart
I used his intake flanges for my 6 Mikuni manifold, they are a little undersized but that way you can open up to what ever size you want.
I used 1 5/8" id tube for the intake.
Richard
PostPosted: Fri Aug 26, 2011 6:01 am
Use 1 1/2 tube for the primaries. 1 5/8 is too hard to make work and unecessary for any slant thats not a full boogie race engine.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Aug 26, 2011 6:34 am
Sounds like fun! 1/2" flange thickness is close to the OEM exh manifold. Mild steel for headers, unless you want to learn to weld stainless and make it all stainless.
Happy building!
PostPosted: Fri Aug 26, 2011 3:06 pm
I used a set of those header flanges. They are very nice pieces indeed. :D
You can get collectors from Schoenfeld.
PostPosted: Sat Aug 27, 2011 10:36 pm
The 1 5/8" round tube has the same area as the 1 3/8"x1 1/4" square opening used in the stock manifolds. You can buy J tubes from Summit for about $14 a piece.
Users browsing this forum: Ahrefs [Bot] and 3 guests
