It is currently Sat Oct 24, 2026 3:29 am
PostPosted: Sun Dec 08, 2002 6:15 pm
So the Dart needs a new exhaust. Found a hole too big to patch.
Figured I'd go ahead and do the performance stuff on the exhaust since it's gotta be done. Was thinking the Clifford dual outlet headers and dual Flowmaster 40s with 2 1/4" pipes and 2" tailpipes to keep enough backpressure to maintain low end torque.
Sound good to you guys?
 Post subject: exhaust
PostPosted: Sun Dec 08, 2002 10:14 pm
I was told by the shop that did my exhaust pipes to the 225 (through dual outlet clifford headers) that unless I'm doing something out of ordinary for that engine like a turbocharger, a single 2 1/4" pipe would be plenty enough. That is what I ended up doing, with a DynoMax SuperTurbo muffler. Supposedly those mufflers are the closest you can get to straight pipe/glasspacks without the noise. I personally hate loud exhasuts, and this setup preforms fairly well while still keeping the noise levels relatively low.
PostPosted: Mon Dec 09, 2002 7:31 am
Yah, Get the best flowmaster you can afford. Noone can compete unless you can live with the sound of a glasspack. I run a glasspack, but I will also be running a turbo very very soon. :)
 Post subject: Re: exhaust
PostPosted: Tue Dec 10, 2002 11:45 pm
Only thing I'm really likely to do is up the compression as much as I can and port the head. Then an EFI conversion with a K&N cone filter, so I would guess all together it could take advantage of it decently.
That and I just LOVE Flowmaster mufflers for their sound (while still not obnoxious) and flow rates.
Users browsing this forum: Ahrefs [Bot] and 15 guests
