It is currently Sun Oct 11, 2026 8:49 pm
 Post subject: Old oil pump
PostPosted: Mon Aug 22, 2011 2:39 pm
Car Model: 1983 d150 a833 vin m
Just replaced the lower end bearings and oil pump on my 83 with **45689 miles.The oil pump drive gear is still good-pump body and rotors are worn out and bearing shown copper but the gear is still good.Doc still interested in one of theese originals- the bearing are also original standard sized.
I may be slow,but I"m ahead of you.
PostPosted: Mon Aug 22, 2011 3:36 pm
I collect all the oil pump drive gears I can find and when I get enough, I send them out for case hardening. (carborizing)
 Post subject: oil pump
PostPosted: Tue Aug 23, 2011 6:24 am
Send me a IM so I know where to send it-I'll send the whole pump if you want.Like I said-its oem original 1983,the engine bearings show production date stamp of june and may-1983.
