It is currently Mon Oct 26, 2026 12:20 am
PostPosted: Thu Aug 25, 2011 8:04 pm
I received this motor disassembled, but now rebuilt and ready to drop into my Coronet this weekend. I can't find a mounting location for this heat shield. Thanks in advance. :?
 Post subject: Easy...
PostPosted: Thu Aug 25, 2011 8:44 pm
Upper two bolts mounting your oil pump to the block..it's a "splash" sheild to protect water from spraying your distributor when you run through a mud puddle.
PostPosted: Thu Aug 25, 2011 8:45 pm
Not a heat shield, it's a splash shield for the distributor. Attaches to the oil pump.
PostPosted: Thu Aug 25, 2011 9:13 pm
It's now installed! Thanks guys.
