904 convertor specs
https://slantsix.org/forum/viewtopic.php?t=46147
Author:  Dave95693 [ Mon Aug 29, 2011 4:04 pm ]
Post subject:  904 convertor specs
Does the crankshaft guide hub on the converter vary in size or change over the years? I thought all 225 904's had a 1:55 inch guide hub on the converter. Am I wrong?
Author:  Fopar [ Mon Aug 29, 2011 4:08 pm ]
Yes early engines (crankshaft) had a smaller centering hole in them, later cranks had a larger hole.
That is why I run a stock converter in my Dart.
Richard
Author:  Dave95693 [ Mon Aug 29, 2011 4:16 pm ]
Post subject:  904 specs
Howdy Richard! Good to hear from you.
So if I have a converter made, they have to know first how many splines on the input shaft and the year of the crankshaft...yes?
Author:  Fopar [ Mon Aug 29, 2011 4:43 pm ]
That sounds correct, early trans had smaller input shafts, later ones had larger input shafts. The crank could be used from a newer (say mid-70's) that would have the larger hole in the end of it and if it's from an older mid/earlier-60's will have smaller hole in the end.
Richard
Author:  wjajr [ Tue Aug 30, 2011 5:11 am ]
I think 1967 was last year of small end crank.
