| Master cylinder conversion https://slantsix.org/forum/viewtopic.php?t=4616 |
| Author: | persons [ Tue Dec 10, 2002 8:25 pm ] |
| Post subject: | Master cylinder conversion |
should you run the rear or front line off the master to prop. valve ? Do you run line out of prop. valve to the T to front lines, or to the rear line? Am I close or way off? |
| Author: | Matt Cramer [ Sat Dec 14, 2002 7:43 pm ] |
| Post subject: | prop valves |
The valve goes in the line coming out of the front (smaller) reservoir on the master cylinder, which then goes through the stock combo valve and then to the rear axle. |
