stock cam question
https://slantsix.org/forum/viewtopic.php?t=4621
Page 1 of 1
Author:  Jerry T [ Wed Dec 11, 2002 12:57 pm ]
Post subject:  stock cam question
Can anyone tell me if the 77 2bl cam is the same as the 79 1bl cam? My oil pump gear tore up my cam gear in my truck so I need to change cams. Does anyone sell a new stock type cam that would be good in a truck?
Jerry
Author:  Doctor Dodge [ Wed Dec 11, 2002 10:40 pm ]
Post subject:  Cams and More Cams...
There are lots of cams to choose from.
You can get a "regrind" to factory specs pretty cheap.
As for the 2 bbl vs. the 1bbl cam, they are the same.
Here are some of the factory cam specs:
http://www.dutra.org/pictures/engine/st ... -specs.jpg
If you need to change cams, why not get a mild performance cam?
You may want to read through this article.
http://www.slantsix.org/articles/oil-pu ... report.htm
