| Shim head gasket https://slantsix.org/forum/viewtopic.php?t=46228 |
| Author: | 65CrewCabPW [ Mon Sep 05, 2011 11:58 pm ] |
| Post subject: | Shim head gasket |
The place I bought my shim head gasket seems to have stopped selling them, so I was wondering if there's a regular source people go to to get more of them. I am still thinking about changing camshafts, and I'll need a new head gasket so I can pull the head and change the lifters. Links? thanks |
| Author: | Rick Covalt [ Tue Sep 06, 2011 3:37 am ] |
| Post subject: | Charlie |
Charlie Schmid on here has them for sale. Rick |
| Author: | Rug_Trucker [ Tue Sep 06, 2011 4:43 am ] |
If you have a drool plug head? No need to pull the head to change the lifters. |
| Author: | Dart270 [ Tue Sep 06, 2011 5:03 am ] |
Yep, '74-down heads you can easily get the lifters out with mag pickup and/or long needle nose. I have done cam swaps many times w/o head removal. Lou |
| Author: | Jeb [ Tue Sep 06, 2011 7:40 am ] |
On my 82 (peanut plug heads) I can pull the lifters with a lifter removal tool. The pushrods go through a hole that is just big enough to get the lifter out of. |
| Author: | Dart270 [ Tue Sep 06, 2011 8:03 am ] |
Good point. Only the '76-80 (or '76-79) heads do not allow lifter removal. Lou |
| Author: | 65CrewCabPW [ Tue Sep 06, 2011 9:22 pm ] |
I guess it wasn't enough to say that I have to pull the head to change the lifters. Do I HAVE to take pictures to show you precisely which head I have, so that you'll believe me? I have a bent pushrod, too. No clue how or why, but you can see it's bent. In any case, after much effort to find the leaks and fix the idle, I sort of have a smooth idle now, that still lopes when the closed loop controller is in and running at stoich (on propane). I just don't know if I can gain enough down low torque to justify the costs. I really need this engine to crank on at 1600 to 3000. |
| Author: | Brussell [ Thu Sep 08, 2011 11:54 am ] |
