It is currently Sat Oct 24, 2026 9:34 pm
 Post subject: Which engine?
PostPosted: Wed Dec 11, 2002 2:02 am
I've got a 63 Valiant and I would like to know which size engine I've got. Is there a serial # on the motor that will tell me what size motor it is? There's nothing obvious in the engine compartment (no sticker on the aircleaner)
Thanks!
 Post subject: RE: Which Engine
PostPosted: Wed Dec 11, 2002 6:28 am
Look for a number stamped into the top surface of the block, on a pad not covered by the head, near the alternator. That should identify it for you.
PostPosted: Wed Dec 11, 2002 10:59 pm
Look right behind the alternator, you may have to clean the location to see the numbers.
