It is currently Sun Oct 25, 2026 8:07 am
 Post subject: stock cam question
PostPosted: Wed Dec 11, 2002 12:57 pm
Can anyone tell me if the 77 2bl cam is the same as the 79 1bl cam? My oil pump gear tore up my cam gear in my truck so I need to change cams. Does anyone sell a new stock type cam that would be good in a truck?
Jerry
 Post subject: Cams and More Cams...
PostPosted: Wed Dec 11, 2002 10:40 pm
There are lots of cams to choose from.
You can get a "regrind" to factory specs pretty cheap.
As for the 2 bbl vs. the 1bbl cam, they are the same.
Here are some of the factory cam specs:
http://www.dutra.org/pictures/engine/st ... -specs.jpg
If you need to change cams, why not get a mild performance cam?
You may want to read through this article.
http://www.slantsix.org/articles/oil-pu ... report.htm
Users browsing this forum: Google [Bot] and 14 guests
