| 7 1/4 weight https://slantsix.org/forum/viewtopic.php?t=46252 |
| Author: | raPoM [ Thu Sep 08, 2011 3:23 pm ] |
| Post subject: | 7 1/4 weight |
Anyone know how much a 7 1/4 rear weighs? Just the rear no brakes/backing plates. Think its under 100 lbs? |
| Author: | Dart270 [ Thu Sep 08, 2011 5:14 pm ] |
Depends on BBP or SBP and a few other things (diff type), but I'd say 105 lbs would be close with no brakes or backing plates at all. Lou |
| Author: | raPoM [ Thu Sep 08, 2011 5:15 pm ] |
Its a SBP open 3.23. Greyhound has a 100 lb weight limit,im hoping it is at that or a little lighter. |
| Author: | Mike'68Dart [ Thu Sep 08, 2011 5:29 pm ] |
I just put my old one on the bathroom scale, ( I took it from the bathroom...), and it read 111.5lbs. It is compleat minus all of the brake hardware except backing plates, slave cyls and brake lines plus a bit of road grime. SBP 2.76 out of my '68 Dart Mike |
| Author: | Mike'68Dart [ Thu Sep 08, 2011 5:38 pm ] |
I think Dart270 is just about right. Might be able to drop a few more lbs if it was drained of all the gear lube, but it will be right at 100+lbs without any "packaging" Mike |
| Author: | raPoM [ Thu Sep 08, 2011 5:41 pm ] |
Mike and Lou, thank you both for all of the info. Thank you Mike for the manual labor |
| Author: | Mike'68Dart [ Thu Sep 08, 2011 5:49 pm ] |
Well, it was not "that much" labor, it is still in the drive way, right where I left it. |
| Author: | raPoM [ Thu Sep 08, 2011 6:07 pm ] |
Could do that,its all up to the seller and how much work he wants to do for me on a cheap part like that. Shipping is going to cost$$$ I am trying to get a "cheap" upgrade,its already starting to add up |
| Author: | MotoGrey [ Mon Feb 06, 2012 11:53 am ] |
| Post subject: | 7.25 compared to 8.25 |
Anyone know how much more the 8.25 weighs over the 7.25? Is the difference enough to affect fuel economy, performance our handling in an early A-body? |
| Author: | Doc [ Mon Feb 06, 2012 12:26 pm ] |
Quote: Could do that,its all up to the seller and how much work he wants to do for me on a cheap part like that. Shipping is going to cost$$$ I am trying to get a "cheap" upgrade,its already starting to add up Have the user reuse his current axles and brake assemblies... or ship them in a seperate package. DD |
| Author: | Danarchy [ Mon Feb 06, 2012 12:39 pm ] |
This is in reply to Rapom's post from Sept. 2011. Did you ship the 7.25? Do you still need one? in Texas. |
