It is currently Sun May 17, 2026 12:27 am
PostPosted: Thu Jul 28, 2011 6:49 pm
Hello, finally have enough money (im hoping) to do a standard rebuild.
I have obtained a motor with the 2806830-1 casting, while I have a 2463430-6 IN my Valiant currently.
I want to use the 280.. but not sure if the internals are good..
The motor in the car ran well but was really lacking compression and had a dead cylinder (piston has a small hole)
Would my best bet be to strip the 280.. block (it looks pretty rusty inside as 2 freeze plugs were missing and oil was sludge)
Clean that and use the internals of the other motor as I know they can be balanced and work as they should?
Thanks for any info or suggestions!!
PostPosted: Sat Jul 30, 2011 5:52 pm
Welcome to the forum. Any reason you want to change blocks? All the slant blocks are good and unless you are trying to build for some specific purpose they will all work just fine.
I would use whats in the BEST shape.
Frank :?
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Sep 09, 2011 3:26 pm
Thank you, i opted for the original block in the car and pulled the oil pan, its clean as a whistle. Now time to get it to the machine shop :roll:
Users browsing this forum: Google [Bot] and 8 guests
