It is currently Sun May 17, 2026 6:09 pm
 Post subject: Shim head gasket
PostPosted: Mon Sep 05, 2011 11:58 pm
The place I bought my shim head gasket seems to have stopped selling them, so I was wondering if there's a regular source people go to to get more of them.
I am still thinking about changing camshafts, and I'll need a new head gasket so I can pull the head and change the lifters.
Links?
thanks
'81 W150 on Propane... Oversize valves, Oregon Camshaft cam, 10:5 static CR, Distributorless ignition, megajolt timing controller, PowerTrax lockers.
 Post subject: Charlie
PostPosted: Tue Sep 06, 2011 3:37 am
Charlie Schmid on here has them for sale.
Rick
PostPosted: Tue Sep 06, 2011 4:43 am
If you have a drool plug head? No need to pull the head to change the lifters.
PostPosted: Tue Sep 06, 2011 5:03 am
Yep, '74-down heads you can easily get the lifters out with mag pickup and/or long needle nose. I have done cam swaps many times w/o head removal.
PostPosted: Tue Sep 06, 2011 7:40 am
On my 82 (peanut plug heads) I can pull the lifters with a lifter removal tool. The pushrods go through a hole that is just big enough to get the lifter out of.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Tue Sep 06, 2011 8:03 am
Good point. Only the '76-80 (or '76-79) heads do not allow lifter removal.
PostPosted: Tue Sep 06, 2011 9:22 pm
I guess it wasn't enough to say that I have to pull the head to change the lifters. Do I HAVE to take pictures to show you precisely which head I have, so that you'll believe me? I have a bent pushrod, too. No clue how or why, but you can see it's bent.
In any case, after much effort to find the leaks and fix the idle, I sort of have a smooth idle now, that still lopes when the closed loop controller is in and running at stoich (on propane). I just don't know if I can gain enough down low torque to justify the costs. I really need this engine to crank on at 1600 to 3000.
PostPosted: Thu Sep 08, 2011 11:54 am
:shock:
Users browsing this forum: Google [Bot] and 7 guests
