| / 6 horsepower https://slantsix.org/forum/viewtopic.php?t=4629 |
| Author: | rez [ Thu Dec 12, 2002 9:58 am ] |
| Post subject: | / 6 horsepower |
i am looking to buy a 73 dart w/ a /6. what is the horsepower rating for this car(225/6)? also, with a mild rebuild(60 over, bigger valves,better intake and exhaust, 2bl. carb)what horse power can i achieve. |
| Author: | slantzilla [ Thu Dec 12, 2002 5:10 pm ] |
In all seriousness, a '73 motor will make about 110 hp. With the stuff you want to do you'll make it to about 160 or so. |
| Author: | DusterIdiot [ Sun Dec 15, 2002 12:44 am ] |
My slant is what I consider to be a "mild" rebuild and I like it for daily driver use.... Super Six w/ stock Carter BBD Comp Cams 252s 9.22:1 compression (.1 milled off block and head total) Stock valves with ported head and Bronze Guides .020 over pistons It definately has"umph" where you need it, I think more carb and more gears would help it, I think I'm getting around 130HP plus or minus. If I went oversize valves, and 60 over. I'd be looking at a 4barrel carb and Dutra Duals or Headers....My car has stock "Feather Duster" Exhaust but I think a bit more exit would help the motor at highway speeds.... -D.Idiot |
| Author: | Jopapa [ Sun Dec 15, 2002 1:25 am ] |
How about a Slix with an electronic ignition, ported head, larger valves, Dutra Duals w/ dual Flowmaster exhaust, and an EFI conversion w/ a larger bore throttle body? That oughta make it nice and mean, eh? |
