It is currently Thu May 28, 2026 1:14 am
 Post subject: 10" drum swap suprise
PostPosted: Mon Sep 12, 2011 11:09 pm
I did the 9" to 10" drum swap, as I had a 10" setup available. Just discovered that orig 13" rims don't fit on 10" drums - the bent part of inner rim web holds wheel 1/2" from drum face. Dang. Thought I could keep still ok tires & hubcaps. Guess I am in the market for SBP 14" wheels eh?
'64 Dart 270 conv
'60 Metropolitan
PostPosted: Mon Sep 12, 2011 11:13 pm
Which 10" drums? A friend had a '66 Barracuda with 10" drums and 13" wheels as original.
PostPosted: Tue Sep 13, 2011 5:09 am
There are different types of 13" wheels, and IIRC the early ones will not fit drums bigger than 9" (or SBP discs).
PostPosted: Tue Sep 13, 2011 8:43 am
Yes, there are two different rim types for the 13" and the eariler ones do not work w/ 10 drum brakes.
The good news, I have some extra "wide face" SBP 13" rims and even a set of 14" SBP wheels & tires... in Sunnyvale, CA so drop me a PM.
