| Ford valves, will this work? https://slantsix.org/forum/viewtopic.php?t=4635 |
| Author: | alienduster [ Fri Dec 13, 2002 1:09 am ] |
| Post subject: | Ford valves, will this work? |
The slant needs a valve job. However, with 60K original miles a leakdown/compression test showed there was no need for a bottom rebuild. I was thinking to port and install ford 300 valves, but will this work with no overbore? Looking at adding a CC 264 and headers at the same time. TIA |
