| Thoughts on this carb? https://slantsix.org/forum/viewtopic.php?t=46460 |
| Author: | Jljde [ Tue Sep 27, 2011 7:18 am ] |
| Post subject: | Thoughts on this carb? |
http://cgi.ebay.com/ebaymotors/1962-PLY ... 4aaef155a2 |
| Author: | Matt Cramer [ Tue Sep 27, 2011 7:33 am ] |
Almost certainly needs a rebuild, but I'll take it over a parts store rebuilt unit any day and rebuild it myself (if I were still running carbs). Even if you have no carb rebuilding experience whatsoever, it would be difficult to do as poor a job as the companies that supply parts stores with their rebuilt carbs. |
| Author: | Brussell [ Tue Sep 27, 2011 7:55 am ] |
From little experience I have it looks all right, looks in the same condition the original carb on my car had which had easily been around the clock 2 - 3 times. Find a good rebuild kit from a decent supplier and go ahead. I'm sure SSD will chime in with a full response! |
| Author: | SlantSixDan [ Tue Sep 27, 2011 8:42 am ] |
Probably a relatively good candiate for a rebuild, but still a bit of a gamble; could be corroded inside beyond effective cleanup. Also, it's from a pre-1967 170 engine and so is a really small carb (smallest venturi, small throttle bore). It is equipped for PCV, so the car was a California or New York unit or was ordered with PCV which was not standard equipment in all the states until '63. |
| Author: | Jljde [ Tue Sep 27, 2011 6:48 pm ] |
So am I better replacing a jacked up choke, various old and worn out parts and all the old springs and such that can "plug and play" so to speak? |
| Author: | SlantSixDan [ Wed Sep 28, 2011 12:15 am ] |
Quote: So am I better replacing a jacked up choke, various old and worn out parts and all the old springs and such that can "plug and play" so to speak?
Um…Operator? |
| Author: | Rug_Trucker [ Wed Sep 28, 2011 5:31 am ] |
I thought '65 was the PCV year on Mopars? |
| Author: | SlantSixDan [ Wed Sep 28, 2011 6:23 am ] |
Quote: I thought '65 was the PCV year on Mopars?
California cars got PCV instead of road draft tube starting in '61. New York starting in '62. Nationwide + export for '63. The breather inlet was originally vented to atmosphere. Starting in '64 (California) and '68 (nationwide + export), the breather inlet was ducted to the carburetor air cleaner. This holds for all makes -- not just Mopars. |
| Author: | Rug_Trucker [ Wed Sep 28, 2011 11:02 am ] |
If that is true the BBS on the '72 slant I just bought is really old! Ok I remember where I got '65 from. 65 was the year the SB BBD's got a wire and stud to mount the air cleaner. |
| Author: | SlantSixDan [ Wed Sep 28, 2011 11:05 pm ] |
Quote: If that is true the BBS on the '72 slant I just bought is really old!
Show us a picture.Quote: Ok I remember where I got '65 from. 65 was the year the SB BBD's got a wire and stud to mount the air cleaner.
'66, except on Barracudas which got it in '65.
| Author: | Rug_Trucker [ Fri Sep 30, 2011 8:05 pm ] |
Digicam crapped out. I'll get the GF to take a pic and I'll email it to someone. |
