It is currently Fri Nov 27, 2026 8:41 am
 Post subject: Going digital
PostPosted: Mon Oct 03, 2011 7:10 pm
I gave up on my speedometer and decided to go digital. Anybody know what transducer will screw into my A833OD? All the instructions say deal with Ford or Chev.
PostPosted: Mon Oct 03, 2011 7:39 pm
See here. Why giving up on your speedometer?
PostPosted: Mon Oct 03, 2011 7:41 pm
Lots of 1990s Chrysler/Dodge/Plymouths have an electronic sender that fits in the tailhousing of earlier transmissions. My '96 Dakota was that way. They are fairly cheap new, but don't come with a drive gear. Try STANDARD MOTOR PRODUCTS Part # SC105 or AIRTEX / WELLS Part # 5S4684 which appears to come with a plug and wires.
PostPosted: Mon Oct 03, 2011 10:58 pm
Dan, I broke the needle and it would not glue back together. I also cracked the plastic on the cable, so even if I did find another needle, it would pop off when I hit a bump. But mainly because I want a digital speedo, and my dad already bought it for me.
Thanks for the part numbers! Now pay day needs to hurry up.
PostPosted: Tue Oct 04, 2011 5:16 pm
That's easy, a NAPA Echlin VSS 232 will thread right in place between the top of your speedo cable and the back of your speedo
No good, I believe that unit is discontinued.
Olaf.
Aspenized
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 5 guests
