Removing Front Fenders on 67 Dart
https://slantsix.org/forum/viewtopic.php?t=46497
Author:  Daddiojoe [ Fri Sep 30, 2011 6:51 am ]
Post subject:  Removing Front Fenders on 67 Dart
Any tips? Looks like they are spotwelded, as opposed to being bolted on, as is the case w/ my D100.
Thanks,
Joe
Author:  exoJjL [ Fri Sep 30, 2011 2:19 pm ]
Not really sure why they would be. Maybe there's a bolt somewhere you missed? Also they used some kind of weather striping on the fenders to reduce rattle. After 40+ years it kind of looks like glue and works like it. A rubber mallet works to knock the fender loose. Also there's a stud inside the fender below the A-pillar.
Author:  Rick Covalt [ Fri Sep 30, 2011 5:22 pm ]
Post subject:  Where?
Where is it tight? The fenders should unbolt and not be welded in place. Not sure about your year but the earlier A bodies have a bolt/Stud at the far rear of the fender that has to be unbolted, up from the bottom with the door open, or with the splash shield removed and go up under the fender. Give us a little more detail.
Rick
Author:  USAJon [ Sat Oct 01, 2011 5:45 am ]
my 1968 HT bolted right off/I think 1967's r the same
I did remove doors to get to the lower rear botl to make it easy
an dmake repaires on the doors too.
Author:  exoJjL [ Sun Oct 02, 2011 1:15 pm ]
That's how i've done it to.
Apparently it's easier to remove the splash shield without removing the door.
Author:  Rick Covalt [ Sun Oct 02, 2011 1:37 pm ]
You can also stand on your head, and act like a contortionist and take a long extension or 2 with a deep well socket and a universal joint and go up between the fender and door. Not the easiest but it can be done.
Rick
Author:  exoJjL [ Tue Oct 04, 2011 3:15 am ]
I believe you. I tried getting about 3.5 feet of extentions on the ratchet that way the ratchet is down below the fender between the door and the series of extensions can bend.
