It is currently Tue May 26, 2026 11:47 am
PostPosted: Sat Sep 24, 2011 11:43 am
Hey guys,
been to my local parts house a few couple times now, and even ordered in some lug studs, only to find out they were the wrong ones.
Does any one have a part number for replacment lug studs for a 65 dart?
loooking to replace a few bent ones and finish converting driver's side to right hand thread. Closest i found were 7/16 thread studs with a 0.47 knurl. which i think would work good EXCEPT the overall lengths of these studs is 1/8 inch or so too long. (tried them and cannot slip them in behind the hub.)
Franklyn
1965 Dart GT - 1949 Plymouth Special Deluxe
PostPosted: Sun Oct 02, 2011 4:27 pm
Try this link.
Be advised that the original studs on the driver's side were LH thread. Most pump jockeys back in the day were ignorant of this, so you can be sure the newer guys don't know it. As a result a bunch got broken by air impact wrenches. Even though it's not "correct" you'll save yourself a lot of grief by going to RH thread lug studs.
Bon chance.
[url]http://www.dormanproducts.com/gsearch.aspx?q=Lug stud+inmeta:year%3D1965+inmeta:make%3DDODGE+inmeta:model%3DDART+inmeta:engine%3DL6%2520%252D%25203%252E7L%2520%2528225%2520CID%2529%253A%2520GAS%253A%2520CARB%253A%2520N%253A&dnavs=inmeta:year%3D1965+inmeta:make%3DDODGE+inmeta:model%3DDART+inmeta:engine%3DL6%2520%252D%25203%252E7L%2520%2528225%2520CID%2529%253A%2520GAS%253A%2520CARB%253A%2520N%253A[/url]
You can't fix stupid. - Ron White
