| valve adjustment https://slantsix.org/forum/viewtopic.php?t=46521 |
| Author: | mangeles [ Sun Oct 02, 2011 10:40 am ] |
| Post subject: | valve adjustment |
I'm a newbie to slant six motors and overall mechanic. I've followed alot of recommendations from this site and have done some work on my slant six. So I pulled the valve cover off of my 1986 dodge d100 and was ready to do a valve adjustment and to my surprise I couldnt find an adjustment screw or bolt to adjust my valves. Am I missing something or are these valves non adjusting? http://i120.photobucket.com/albums/o164 ... 1020_1.jpg |
| Author: | Guido [ Sun Oct 02, 2011 10:53 am ] |
You have an hydraulic valve train. The earlier engines are mechanical. Guido |
| Author: | SlantSixDan [ Sun Oct 02, 2011 11:20 am ] |
Welcome on the board. Slant-6 engines starting in 1981 had hydraulic, non-adjustable valvetrains. |
| Author: | mangeles [ Sun Oct 02, 2011 1:35 pm ] |
Cool thanks! I had rough idle and it shuts off every once and a while. So i guess my next move is to look at the carb? |
| Author: | Reed [ Sun Oct 02, 2011 3:39 pm ] |
If I were you, my next move would be to determine f the vehicle had one of the notorious "lean-burn" systems on it. The Lean Burn systems used by Chrysler in the 80s are notoriously failure prone. |
| Author: | mangeles [ Sun Oct 02, 2011 8:14 pm ] |
I'll check it out and see if the lean burn is installed. Thanks. |
