It is currently Fri Nov 27, 2026 8:52 am
 Post subject: Slant six scattershied
PostPosted: Wed Oct 05, 2011 2:36 pm
I would like to try and modify a small or big block scattershied to fit a slant six. I wondered if any else had tried this and had some sugestions or advice
PostPosted: Wed Oct 05, 2011 3:16 pm
Contact member Dart 270 (Lou). He has an adapter plate specifically for putting a Lakewood small block scattershield on a Slant.
I have a small block Lakewood if you're interested.
Quick Time was going to make a shield for a Slant. Not sure if they ever did or not.
PostPosted: Wed Oct 05, 2011 3:29 pm
I have a Quick Time safety bellhousing, but haven't installed it yet. There is no provision for a Z-bar so it's fab a bracket or go hydraulic.
PostPosted: Thu Oct 06, 2011 6:03 pm
The one thing about using a Lakewood, you do have to use a 130 tooth flywheel. A V-8 one will work if you enlarge one bolt hole.
 Post subject: Lakewood belhousing
PostPosted: Sun Oct 09, 2011 11:32 am
I did this on my slant. When I do it again I will use a 440 bellhousing. The 340 pattern lays on the slant bolts so I had to go with some countersunk bolts which makes it a little harder. It can be done, and I have not seen Lou's adapter. I had Mcload make me a 340 flywheel with a slant 6 flange. That lets you use almost any clutch combo. I used the green cover mopar hemi pressure plate with a carbon fiber disk. I sold my set up to Ron in MA for his lancer. Not sure if he has installed it. You also need a starter that does not use a nose support. ? you can PM me. Stan
 Post subject: Headers
PostPosted: Mon Oct 10, 2011 1:24 pm
Hi Stan! What headers were you using? The smallblock bell puts the starter in the low position.
Pretty sure Ron is running yours in the car now.
Rick Covalt
 Post subject: Re: Headers
PostPosted: Mon Oct 10, 2011 2:13 pm
Rick Covalt
It mounted right in the stock location above the pan. That is why you need the starter. I tried to build a pocket for the stock starter nose but I could not get it right in my backyard machine shop. If you use a no nose starter it just has to align with the flywheel and your set. Mine was a Tilton but they are commonly called import diesel starters. I was running the Hooker race headers, 2 part headers, front and rear. I had the most trouble with the z-bar not the starter or bellhousing.
 Post subject: Thanks
PostPosted: Mon Oct 10, 2011 4:41 pm
Thanks Stan,
I have one of the aluminum adapters that Mark Goodman made up also. It just removes the front scattershield plate and replaces it with the 1/4" aluminum plate with the slant pattern. He did a great job on it and sent me all the countersunk bolts...etc.
When I install mine I am pretty sure that my long tube Clifford's are going to be a problem around that low starter. That is why I was wondering what you used. My car is a 65 Valiant also. Thanks for the info.
Rick
 Post subject: starter
PostPosted: Mon Oct 10, 2011 7:27 pm
it would be easy to move a starter up. just mount a stock bellhousing and transfer the pattern to the adapter. good luck with your project
