| Balancer https://slantsix.org/forum/viewtopic.php?t=46565 |
| Author: | Tinker67d100 [ Thu Oct 06, 2011 7:09 pm ] |
| Post subject: | Balancer |
Hi I have a 67 d100 , i was told that I have a forged crank and is uses a different balancer that /6 with a cast crank , thanx for any info |
| Author: | slantzilla [ Fri Oct 07, 2011 4:03 pm ] |
No, the difference is in the placement of the timing marks. IIRC, they changed in the late '60's, so you will need an early damper. A cast crank damper will fit/work, but your timing tab will not align with the mark on the late damper. |
| Author: | Tinker67d100 [ Sun Oct 09, 2011 1:57 pm ] |
Thank you ,I did want to use one that was harmful to the motor |
