Water cooled bearing housing hook up?
https://slantsix.org/forum/viewtopic.php?t=46571
Author:  Turbo Toad [ Fri Oct 07, 2011 12:56 am ]
Post subject:  Water cooled bearing housing hook up?
I'm working on a tight fit turbo header with a new turbo that's a water/oil cooled bearing housing and I'm wondering how to hook the water Inlet and return lines up I was thinking I could run the Inlet and return off the water pump lines and bypass the heater core how is everybody else running there lines?
Aaron
Author:  Dart270 [ Fri Oct 07, 2011 4:02 am ]
I believe that is how it's done. Could leave htr core in line too as that will do nothing but help cooling.
Author:  Turbo Toad [ Wed Oct 12, 2011 7:01 pm ]
Thanks Lou that's how I thought it was done and I didn't think about running it thru the heater core
Thanks Aaron
Author:  Matt Cramer [ Thu Oct 13, 2011 8:27 am ]
Yep, used heater core lines on the Mitsu turbo I used to have. (The GT40 going in there is purely oil cooled.)
