It is currently Wed May 27, 2026 5:38 am
 Post subject: breaded line back lines
PostPosted: Fri Oct 14, 2011 1:40 pm
I am almost done installing my kh disc converstion but hit a road block.
I need the flex lines. Do I make the hard lines longer and use the lines I have now or is there a longer flex line?
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Fri Oct 14, 2011 2:59 pm
What's wrong with using the stock replacement KH hoses?
PostPosted: Sat Oct 15, 2011 11:15 am
Did not know there was kh lines. Does anyone know a part number or supplier
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Sat Oct 15, 2011 11:21 am
Try rockauto.com if you don't have any local parts stores around you.
PostPosted: Tue Oct 18, 2011 8:03 am
I know that this might be a stupid questions but do I ask the parts store for a kh brake line and try to explain to a bunch of chevy and ford people what i am looking for. I have the two part version with the hub and rotor, not sure what year it came from. I would love a history lesson
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Tue Oct 18, 2011 11:20 am
What is it going on? I know the kh setup was used through 72 on a bodies, I'm not certain of start year, maybe 68? So if you asked for a 70 duster disc brake hose you would get the right one.
PostPosted: Tue Oct 18, 2011 10:56 pm
I have a 67 dart 270 that had 9" drums to start. Thank I ordered a set from rockauto. Thanks for the info and if I am missing anything else I will ask. It has taken me about 8 years to get to were I am and I don't have the time nore the money to make mistake anymore
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
