Cam thoughts.
https://slantsix.org/forum/viewtopic.php?t=46593
Author:  75customdart [ Sun Oct 09, 2011 6:54 am ]
Post subject:  Cam thoughts.
Just wondered how you would run this cam? Compression ratio, gears, timing and how you would degree it. Thanks Cory Image
Author:  sandy in BC [ Sun Oct 09, 2011 7:18 am ]
I run mine with a 5 speed and 3.55 gears,
Ground 4 degrees advanced ...installed straight up
9.25:1 CR
Author:  DusterIdiot [ Sun Oct 09, 2011 9:38 am ]
Post subject:  x2
I've run the same cam in two iterations:
1) A833OD and 3.55 gears, installed straight up (111+4 means the cam is ground with the 4 degrees advance). Worked great for hyperpak, 390 or 600 cfm Holley and 10.3:1 static compression.
2) Currently installed in my other duster at A-230 3spd and 3.55 gears, 10.3:1 SCR, 390cfm Holley, Offy 4 barrel intake.
It likes the top end a bit, but is still fine on the bottom end.
Author:  75customdart [ Mon Oct 10, 2011 11:02 am ]
Thanks for the input guy. Think I'll bring the compression up a little before I put the motor in my dads car.
