It is currently Mon Sep 21, 2026 10:37 pm
 Post subject: 74 Plymouth Duster
PostPosted: Tue Oct 11, 2011 9:10 am
I just bought a 74 Plymouth Duster (with Slant Six of coarse).
This car is coming from California (California Car) to where I live in central Florida.
I would like your opinion(s) on any changes/modifications that I should make with the climate change (or changes / things to check/do in general).
Thermostat? Oil grade? Fuel grade? Timing/mixture? etc?
The car is currently in near running condition. The near running is because it needs a carb kit which I already have to put on it. I will also be giving it a complete tune-up regardless of whether the part needs to be changed or not (plugs, wires, belts, PCV valve, etc; basic stuff).
Anyway, when you have a moment, can you tell me your thoughts on things I should do, check, change, etc to bring this car to peak performance.
Any thoughts/recommendations you have are appreciated.
Thank you all!
1974 Plymouth Duster
PostPosted: Tue Oct 11, 2011 9:22 am
Hello and welcome. I suggest you read THIS thread (click on the red text) and the threads referenced in that thread.
 Post subject: Thank you!
PostPosted: Tue Oct 11, 2011 1:31 pm
Thank you for your response. I think those threads covered everything well minus anyone's person thoughts/feelings/experiences and the following:
based on a central Florida heat/climate?
Thank you all again.
PostPosted: Tue Oct 11, 2011 2:06 pm
Thermostat? Get a Stant Superstat of the stock temperature rating. If you are worried about overheating, or if the Duster is already overheating, you need to get the rest of your cooling system cleaned out and repaired before you do anything like run a colder thermostat. Get a fan shroud and/or a larger radiator if you are still running hot.
Oil grade? Depends on the condition of your motor. Here in the Pacific Northwest, I run 5W-30 year round on all my family's daily driver motors. No problems on motors with less than 50k to more than 115K. Select your oil viscosity based on severity of service, average ambient temperatures, and condition of the motor.
Fuel grade? On a stock motor there is no need to buy anything with a higher octane rating than 87 (regular).
PostPosted: Tue Oct 11, 2011 4:14 pm
nroberts,
On my 74 Swinger I run the stock 195 degree stat, 0-30W Mobile 1, 87 octane fuel.
Stay with the 16# radiator cap.
Since the fuel has changed (10% or more ethanol) I use plugs two heat ranges cooler from stock.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 11 guests
