Help ID'ing Vintage Headers
https://slantsix.org/forum/viewtopic.php?t=46638
Page 1 of 1
Author:  carpdar [ Thu Oct 13, 2011 4:02 pm ]
Post subject:  Help ID'ing Vintage Headers
Hey got these at a swap meet and they are different from anything i've seen before. The Headers join at the 4th runner, and the 4th runner flange is attached to the 3rd with some sort of heat pickup tube for the factory choke i assume... check it out. My guess is it fits a 63-66 a body
Aaron
Author:  Nongan [ Thu Oct 13, 2011 4:09 pm ]
IMO they look like AMC 232/jeep 4.0l headers since the two center tubes meet together.
My two cents
Author:  Mike'68Dart [ Thu Oct 13, 2011 4:39 pm ]
To add to that, the slant only has ONE mounting bolt hole, on the top of, the 3-4 flange.....
Mike
Author:  87D100 [ Thu Oct 13, 2011 4:47 pm ]
Mike
That "one" hole would be on the intake, not the exhaust :D Those def. are not Slant headers, I can tell u that.
Kevin
Author:  Mike'68Dart [ Thu Oct 13, 2011 4:53 pm ]
Mike
Kevin
You are correct!! :oops: I was looking at the head I have in the shop, and didn't count the ports. I am still new to the slant, coming from Pontiac V8s.
Mike
Author:  olafla [ Thu Oct 13, 2011 5:01 pm ]
The little heat pickup tube was used with Autolite/Motorcraft carburetors with hot air choke, I don't know if others used them as well. It is not Ford headers, they had the pipes on the other side.
Olaf.
Author:  Dart270 [ Fri Oct 14, 2011 1:41 am ]
Definitely not Slant 6 headers. AMC is a good guess.
Author:  SlantSixDan [ Fri Oct 14, 2011 1:44 am ]
Almost all automatic chokes except most '60-up Mopars used a heat tube.
Author:  Tim Keith [ Fri Oct 14, 2011 5:19 pm ]
Those appear to be Datsun L series six, for a 240Z maybe.
http://www.thezstore.com/page/TZS/CTGY/PEC25
Author:  carpdar [ Tue Oct 18, 2011 5:25 pm ]
i bought them at a swap meet from a guy who claims they are mopar.. what i should do is figure out the runner separation measurements. I want to sell them though since im just going to stick to my iron manifold for the original appearance
Author:  Nongan [ Tue Oct 18, 2011 5:55 pm ]
Here is the manifold off a 200? Jeep with a 4.0 HO inline 6, note the bottom mounting holes on the outsides. I will have to look at my friends AMC 232 but I'm 99% sure his exhaust manifold has the same holes, I know 100% that the ports are the same.
mopar manifolds are still prone to cracking :lol:
the intake manifold:
Hope this helps with the I.D. 'ing process
Seth
Author:  Nongan [ Tue Oct 18, 2011 6:11 pm ]
here is a 232 stock manifold, it has two holes in the top of the center and the two on the outside.
Author:  Doc [ Wed Oct 19, 2011 8:27 am ]
A quick check with some exhaust manifold gaskets will help confirm the application for these headers.
