It is currently Wed May 27, 2026 8:56 pm
PostPosted: Mon Oct 17, 2011 2:50 pm
Hello everyone,
i am currently replacing my brakes on my 73 scamp. It has 10" drums on front and back. I am running new lines, replacing the master cylinder, replacing the wheel cylinders, etc. I accidentally squished one of the nipples on the proportioning valve and am getting a leak. I need to replace the valve, not sure where to get one or what other ones i can use (can i use one that is not the same shape, are there other years that are compatible). If anyone can help, has one, or has any advice i would appreciate it.
PostPosted: Mon Oct 17, 2011 3:15 pm
www.inlinetube.com has replacement original-type valves.
