Favorite fix for loose lash adjusters?
https://slantsix.org/forum/viewtopic.php?t=46670
Author:  65CrewCabPW [ Sat Oct 15, 2011 5:12 pm ]
Post subject:  Favorite fix for loose lash adjusters?
So far, I've been removing the lash adjuster from the rocker arm, screwing a thin locknut onto it and then doing the obvious, locknutting it in place.
Since I got the motor running 3 months ago, I'm up to 4 with that treatment.
Author:  sandy in BC [ Sat Oct 15, 2011 6:39 pm ]
You can squish the arms in a vice to make things a little tighter.....or if the reason they are backing off is a lot of meat milled off the head or deck....you can use shorter pushrods.
Author:  65CrewCabPW [ Sun Oct 16, 2011 1:40 am ]
Mine are just loose from age and many movements, apparently. I don't have a vice, and taking off the rocker arm to do that seems like a pain.
Years ago, my poly 318 had the same problem, but those were cast rockers, no squeezing them was possible. I ended up using a washer under the hex on top and it just happened to make it tight at the proper clearance.
I've been quoted $50 + shipping for a rebuilt rocker arm assembly, but how are they "rebuilt"?
Author:  Dart270 [ Sun Oct 16, 2011 5:44 am ]
3/8" fine tread jam nuts is another way.
Author:  65CrewCabPW [ Sun Oct 16, 2011 10:22 am ]
that's what I used.
Author:  805moparkid [ Sun Oct 16, 2011 4:49 pm ]
the adjuster set from isky for a 426 hemi work... they have a lock nut and allen head...
they are a little tall with higher lift and hit the baffle but thats an easy fix...
think 1.25" long
Author:  terrylittlejohn [ Mon Oct 17, 2011 5:35 am ]
green locite on the treads help alot.
Author:  Dart270 [ Mon Oct 17, 2011 10:07 am ]
BTW, how do you live w/o a vise? Since age 5, I think I was without one for a couple of months around age 25, and I almost went mad...
Author:  SlantSixDan [ Mon Oct 17, 2011 10:45 am ]
I know, right? Mine are cigareets and whiskey and wild, wild women.
Author:  65CrewCabPW [ Mon Oct 17, 2011 12:41 pm ]
I used to be a mechanic... worked in a diesel shop for 13 years. Now, I have no shop, I lost all my tools ( 3000 worth of Snap hand tools alone) to theft, I don't even have a carport to work under.
So, sorry, no vice. It's a pain, but I rent and have no choice.
Author:  Dart270 [ Mon Oct 17, 2011 12:47 pm ]
Wow, that is terrible.
When I had just a carport in a rental apt in SoCal (6 yrs), I got a hold of an old army footlocker and bolted a Sears vise to it, then filled it with 250 lbs of rear axle and engine parts and locked it. Nobody gonna walk off with that.
Author:  kielbasa [ Mon Oct 17, 2011 4:41 pm ]
my car came with the jam nuts already installed, being a mopar newb, i thought they were suppose to be there. the vw's have them, those germans sure know how to build a motor ;-) theres never a adjuster problem, unless you buy cheap unhardened adjusters from EMPI and they get eaten away in less then 5 minutes
