| What kind of times... https://slantsix.org/forum/viewtopic.php?t=4669 |
| Author: | dustin duster [ Thu Dec 19, 2002 3:27 pm ] |
| Post subject: | What kind of times... |
I just got my slant 3 months ago, I plan on do ing some braket racing. What can i expect from my slant 4bbl offy intake 6 into 1 header and realy lumpy cam, I dont remember the dementions, somthing like 568 thanks |
| Author: | Doc [ Thu Dec 19, 2002 4:42 pm ] |
| Post subject: | Do your homework... |
It all comes down to a good combination of parts. You need to get the actual specs on the cam, a real lumpy cam with a heavy car, tight converter, "tall" rear gear will be slow. On the other hand, I have a 2700 lb car with a 3000 stall converter and 4.56 gears that runs low 14's, with a 170 SL6 DD |
| Author: | dustin duster [ Fri Dec 20, 2002 6:17 am ] |
the lift is .528 and duration is 284 i dont konw howmuch my cars' LBs but it is a 72 duster 455 rear gear |
| Author: | NORM [ Fri Dec 20, 2002 1:53 pm ] |
I HAVE A 73 STOCK DUSTER WITH A OFFY INTAKE AND A HOLLY 4BBL AND RUN ON THE FRONT 2BBL WITH 4.62 GEARS EVERYTHING ELSE IS STOCK AND IT TURNED 10.61 IN 1/8TH LAST WEEKEND. |
| Author: | slantzilla [ Fri Dec 20, 2002 9:51 pm ] |
Sounds like it ought to at least run 12's in the quarter. |
| Author: | dustin duster [ Thu Dec 26, 2002 2:00 pm ] |
| Post subject: | hey just went |
hey just went after christmas hunting and in a old race shop i found a used 4bbl intake ill put it on tom whith a holly demond |
