Couple questions
https://slantsix.org/forum/viewtopic.php?t=46705
Page 1 of 1
Author:  Nongan [ Mon Oct 17, 2011 10:02 pm ]
Post subject:  Couple questions
Ok, so I got a set of autometer electric gauges and I was wondering what the thread size is for the oil pressure sender and water, its a '74 block and head. From autometer its 1/8 thread for both the oil pressure sender and water/oil/trans temp sender. Also where do I install a trans temp sender and oil temp sender?
Seth
Author:  Fopar [ Mon Oct 17, 2011 11:56 pm ]
Seth you will have to install a fitting in both engine and transmission pans low enough to be in the fluid.
Richard
Author:  Nongan [ Tue Oct 18, 2011 11:20 am ]
Yeah I figured I would. Would welding a bolt into the pans work? And can someone answer my other question? What is the thread size of the oil pressure "idiot light" sender, and what is the water temp thread size, just want to know if I have to drill and tap those two to fit a 1/8 thread sender in each one.
Seth
Author:  Fopar [ Tue Oct 18, 2011 11:35 am ]
The temp sender is 1/8" and the oil idiot light is two different sizes check at the oil pump you may have to use an reducer to get the 1/8" on.
Richard
