It is currently Fri Nov 27, 2026 3:07 pm
PostPosted: Mon Oct 24, 2011 9:14 pm
Hi ho list we seem to have had a rear leaf spring collapse on us last week, some moron seems to have taken out one of the leaves you can see the shadow where there should have been a 4th leaf, any how will the springs from a VC etc fit in a 63 AP5 ? thanks RAY
PostPosted: Mon Oct 24, 2011 9:38 pm
In North America, all A-body springs are interchangeable though there's a bracket difference (easily swapped) on '63-down vs. '64-up cars. If that difference holds true in Australia, then the bracket change would be in the middle of AP5 production.
PostPosted: Tue Oct 25, 2011 2:18 am
Thanks Dan 63 and earlier parts are much harder to get then 65 on . I can get a 65 set of new springs for $150 but before i drive 4 hours to check them out wanted a bit of an idea . RAY
