| damper install https://slantsix.org/forum/viewtopic.php?t=46785 |
Page 1 of 2 |
| Author: | kielbasa [ Tue Oct 25, 2011 6:13 pm ] |
| Post subject: | damper install |
Just recieved my ausi made balancer and looks good. Wondering what the easiest way to install, do you heat them up or do I need to buy a longer bolt then what I already have and find a way to lock the motor? |
| Author: | SlantSixDan [ Tue Oct 25, 2011 6:37 pm ] |
Don't heat it up! Installation is by means of an appropriate bolt. An air wrench makes the quickest installation, though a strap wrench can be used if you need to lock the engine. |
| Author: | Fopar [ Tue Oct 25, 2011 8:03 pm ] |
Buy or borrow http://www.jegs.com/webapp/wcs/stores/s ... ation+tool Richard |
| Author: | kielbasa [ Tue Oct 25, 2011 8:20 pm ] |
I've heated up Chevy ones with a propane torch for a min and went on with a few decent taps. But I'm sure its not good for the rubber. I'll just buy a longer bolt and I didn't even think of using my big impact. Thanks |
| Author: | 64 Convert [ Tue Oct 25, 2011 8:20 pm ] |
Longer bolts and large washers of the proper size are often found on Mopar V8's. I keep one just for installing dampers. |
| Author: | Fopar [ Tue Oct 25, 2011 9:23 pm ] |
Longer bolts and large washers of the proper size are often found on Mopar V8's. I keep one just for installing dampers. This would be the cheap and very workable way. Richard |
| Author: | kielbasa [ Tue Oct 25, 2011 9:49 pm ] |
I noticed that this damper has 2 marks, one lines up with 0 and another about 1 o clock what's the 1 oclock position for? |
| Author: | Fopar [ Tue Oct 25, 2011 10:52 pm ] |
Some early engines had timing tab on drivers side (bolted to timing cover). Richard |
| Author: | Joshie225 [ Tue Oct 25, 2011 11:30 pm ] |
Is this other mark a full mark front to back or is it just on part of the damper? |
| Author: | kielbasa [ Wed Oct 26, 2011 7:53 pm ] |
both marks, are only on the back half of the belt groove. (closer to engine) nothing at all on the front half |
| Author: | kielbasa [ Mon Nov 14, 2011 3:12 pm ] |
I finally got my air compressor back home from using it texturing ceilings and walls for a house I've been working on. Anyways, I got the bolt and washer. I oiled up the damper in side and out, but it seems to be quite a tight fit. It started folding the washer and now it seemed like its gauling the threads a little. And with the impact, its actually spinning the entire crank. I don't think its butted down all the way. There is about a 1/4 between bracket and back of damper |
| Author: | Jeb [ Mon Nov 14, 2011 4:53 pm ] |
That is why you need a harmonic balancer installer. Go to your local auto parts store and rent one. It will save you a lot of hassle, and the threads in your crank snout will thank you. Also, the problem with heating things up to install them is that they are a PITA to get back off. I found out the hard way with crank sprocket on my truck. |
| Author: | kielbasa [ Mon Nov 14, 2011 5:28 pm ] |
What's the part number for a decent installer |
| Author: | Jeb [ Mon Nov 14, 2011 5:36 pm ] |
Just go to an autoparts store and ask for a harmonic balancer installer. No part number to it. Most of your major chain brands (except NAPA) have a tool rental program. |
| Author: | kielbasa [ Mon Nov 14, 2011 5:43 pm ] |
Rather buy my own |
| Page 1 of 2 | All times are UTC-07:00 |
