It is currently Wed Dec 24, 2025 12:50 pm
 Post subject: Draining Brake Fluid
PostPosted: Wed Oct 26, 2011 6:28 pm
Just received the last of my ordered brake parts from rockauto. (including master cylinder, drums, etc...)
my current rear brakes are in very bad shape and the fluid looks to be very old (cloudy, off-colored)
I want to get started, but question is, what is the best technique to expel all the old brake fluid?? do this before removing the old m/c and rear brakes?
Franklyn
1965 Dart GT - 1949 Plymouth Special Deluxe
PostPosted: Wed Oct 26, 2011 11:36 pm
Turkey baster to empty the master cylinder (or just leave the cap on it and unbolt and remove; it won't make much of a mess). Likewise go ahead and just remove the old hydraulics and discard them. Once all the new parts are bolted in place, flush the system through with fresh brake fluid til it runs clear from all four corners, then bleed.
PostPosted: Thu Oct 27, 2011 8:52 am
Once all the old cylinders are removed, a quick shot of compressed air at one end of the hydraulic system's hard line(s), does a good job of purging-out any old brake fluid.
Be sure to tie a rag onto the other end of the hard line... or doing this will make a mess.
(warning: you do not want brake fluid getting on any painted surfaces)
PostPosted: Thu Oct 27, 2011 10:00 am
Also, remember to bench bleed the master cylinder before filling up with new fluid for the lines. See earlier posts on the subject.
Not bench bleeding may create problems with air bubbles, which will be near impossible to get rid of later.
Olaf.
Aspenized
PostPosted: Thu Oct 27, 2011 10:02 pm
thanks guys,
looking forward to getting started tomorrow afternoon.
I'm sure i'll have a question or two here and there as I refresh my brakes.
cant wait to get her back on the road!
(still waiting for my FSM!! it has been 8 days since I ordered it and i'm getting impatient ) :lol:
Franklyn
