| (904 ) Adjusting pressure? https://slantsix.org/forum/viewtopic.php?t=46821 |
| Author: | Rick Covalt [ Fri Oct 28, 2011 3:10 pm ] |
| Post subject: | (904 ) Adjusting pressure? |
This may be a dumb question, but I claim to be a 4-speed guy. Thanks, Rick Covalt |
| Author: | Doc [ Fri Oct 28, 2011 3:33 pm ] |
Yes, that is the correct process but the key here is having a oil pressure gauge that reads up into the 200 to 250 psi range. (a 904's main line pressure is 155 to 165 psi) Most just give the screw an extra turn or two. (counter-clockwise rotation will increase the main line pressure) Each turn of the adjustment screw gives you about 10 psi of change. DD |
| Author: | Rick Covalt [ Fri Oct 28, 2011 4:06 pm ] |
| Post subject: | Thanks |
Thanks Doc |
