| Small tube from carb to manifold https://slantsix.org/forum/viewtopic.php?t=47041 |
| Author: | Slanteast [ Mon Nov 21, 2011 6:54 am ] |
| Post subject: | Small tube from carb to manifold |
Good day, my friend is working on my 68 Dart 225 . It is completely original, the tube from the carb to the manifold which appears to be about 5/16'' is corroded away. Is there any service manual illustrations or photos available here? Apparently 69 and up are different, his manual is a 69. He was asking if they where produced with a pinch in them to restrict vacum? Any help would be appreciated. Thanks Derek |
| Author: | SlantSixDan [ Mon Nov 21, 2011 11:26 am ] |
That's a carburetor anti-ice system described here (and in your friend's '69 manual). It's ordinary 1/4" steel tubing and can be re-made if desired from regular (non plastic coated) brake line tube stock. If your local gasoline contains alcohol during the winter -- much of it does; generally this is a province-by-province/state-by-state thing -- then the anti-ice system is unneeded and you can simply connect a piece of vacuum hose between the nipple on the underside of the air cleaner base and the nipple at the carburetor base. Tune-up parts and technique suggestions in this thread. Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download. |
| Author: | Slanteast [ Tue Nov 22, 2011 3:31 am ] |
Thanks Dan this is very helpfull. Derek |
| Author: | neilskiw [ Tue Nov 22, 2011 8:55 am ] |
| Post subject: | Isn't Dan Amazing??? |
Thanks for being You, Dan. |
| Author: | SlantSixDan [ Thu Nov 24, 2011 7:43 pm ] |
Glad to help out, and I don't guess I have much a choice but to carry on being me!
