| Distributor can be turned by hand? bolt is tight. https://slantsix.org/forum/viewtopic.php?t=47068 |
| Author: | 1966DartConvertible [ Wed Nov 23, 2011 6:56 am ] |
| Post subject: | Distributor can be turned by hand? bolt is tight. |
Hi Installed the Aircleaner today and adjusted the timing. The 7/16" bolt beside the distributor is fully tighten but I could still turn the dist by hand! Am I missing something? Is there another bolt holding the dist in place? Thanks. Syed |
| Author: | slantvaliant [ Wed Nov 23, 2011 7:06 am ] |
Take a look at the underside of the distributor and the claw arrangement, to see if the clamp is right. HERE's a photo of one variation. Note the bolt going up into the distributor. That gives two points of adjustment. |
| Author: | 1966DartConvertible [ Sat Nov 26, 2011 5:40 am ] |
Quote: Take a look at the underside of the distributor and the claw arrangement, to see if the clamp is right.
Sorted... Thanks.
| Author: | Sam Powell [ Sat Nov 26, 2011 6:01 am ] |
If you are clever,and lucky, you can get a 7/16" box end wrench on that bottom bolt without taking our the distributor. Sam |
| Author: | 60 Plymouth [ Sat Nov 26, 2011 6:40 am ] |
I've never managed to achieve that - I'll have to get some dead skinny spann - I mean wrenches I do have a steering column in the way though. |
| Author: | Sam Powell [ Sat Nov 26, 2011 6:52 am ] |
Quote: I've never managed to achieve that - I'll have to get some dead skinny spann - I mean wrenches
On the backward American versions, I think you must remove the oil filter to do this. It kind of fits in nicely with an oil change. I change my filter more often than I change oil though. I do have a steering column in the way though. Sam |
| Author: | SlantSixDan [ Sat Nov 26, 2011 8:51 am ] |
See here |
