| Moog part numbers https://slantsix.org/forum/viewtopic.php?t=47087 |
| Author: | hideogumperjr [ Thu Nov 24, 2011 10:47 pm ] |
| Post subject: | Moog part numbers |
I found a upper ball joint part #MOOG-K704 that was listed as fitting my 63 Dodge Dart. I found this part on Amazon for $20 cheaper but their website says it will not fit my 63. Anyone know if this will or will not fit and if there is a list of Moog parts for the 63 Dart? Thanks in advance, John |
| Author: | SlantSixDan [ Thu Nov 24, 2011 10:57 pm ] |
Amazon's part application catalogue isn't worth looking at—it's not even partially complete and it's full of errors. K704 is correct for your '63. |
| Author: | hideogumperjr [ Fri Nov 25, 2011 9:05 am ] |
Is it worth ordering to save 30% as long as the parts are the same? From what I have found I can save a couple of hundred bucks over ordering the front end parts elsewhere, tie rod ends, ball joints, idler arm, pitman arm, bushings, etc. Thanks |
