Trying to locate speedometer adapter and pinion assembly
https://slantsix.org/forum/viewtopic.php?t=47089
Page 1 of 2
Author:  krytellan [ Fri Nov 25, 2011 8:34 am ]
Post subject:  Trying to locate speedometer adapter and pinion assembly
With no luck in my area. Dealerships don't have parts that old, my corner shop can't get 'em, and the junkyards here are barren of old mopars.
Any suggestions? My adapter is cracked, and while I'm at it I was looking to replace the whole assembly, including pinion.
Author:  slantzilla [ Fri Nov 25, 2011 8:42 am ]
How many tooth pinion do you need? I'll be at my shop tomorrow and Sunday. I'm sure I have a dozen housings and pinions laying around. :D
Author:  krytellan [ Fri Nov 25, 2011 8:53 am ]
It's a 31 tooth. I'm assuming my parts are original, and I have the red adapter and green plastic pinion.
I should ask now what price you would be looking at as there is a used one on ebay for $20 (which includes a 27 tooth pinion) that ends in a day. Not really the sure the pinion needs replacing, but it seems the pinion oil seal does... as well as the large O-ring (orange).
Just lemme know if you think I should pull the trigger on the ebay item.
And THANKS so much!
Author:  slantzilla [ Fri Nov 25, 2011 9:16 am ]
I'll send ya mine for the cost of shipping. It will be tomorrow before I can check for sure though. I know I have 2 904's sitting on the floor with pinions in them.
Author:  krytellan [ Fri Nov 25, 2011 9:31 am ]
I'll hitch my horses to your wagon then. I can paypal you as soon as I hear something if you wish. Otherwise, you can PM me with alternate arrangements.
Thanks again.
Author:  slantzilla [ Fri Nov 25, 2011 6:49 pm ]
Sounds good :D
Author:  slantzilla [ Sat Nov 26, 2011 5:32 pm ]
OK, I have housings but no 31 tooth pinions. I have 29, 32, and 33.
I also forgot the housing at the shop when I left tonight. I had 2 laid out and left them both. :oops:
I may go back down tomorrow, but more likely Monday.
Lemme know what pinion you want.
I also called my trans guy to see if he has a 31. They are color codded besides being numbered, what color is yours?
Author:  DusterIdiot [ Sat Nov 26, 2011 8:15 pm ]
Post subject:  I got one if needed...
31 I think is green. I have 2 of them I won't use (don't have any 2.94 vehicles anymore...LOL)...
I'll send ya one for the cost of shipping, need an address.
Author:  krytellan [ Sun Nov 27, 2011 8:00 am ]
You guys are awesome!
The 31 tooth is green, and the adapter is red.
Why don't both of you send me a PM with how you would like your money. I have paypal and that would be easiest, but can send money by snail mail if you wish.
Thanks so much!
Author:  slantzilla [ Sun Nov 27, 2011 11:49 am ]
Just to be sure, the adapter you are talking about is the round aluminum housing that the pinion goes through, correct? Mine are all bare aluminum, I'm guessing your is painted?
Author:  bigslant6fan [ Sun Nov 27, 2011 10:35 pm ]
Post subject:  .
Hate to be a wet blanket, but if he needs one for a mid 70s-up car (the '80 in the pic?) It will be the all plastic adapter thats molded to the cable.
Author:  slantzilla [ Mon Nov 28, 2011 6:09 am ]
That's what I'm trying to find out. I want to make sure we're talking about the same thing.
Author:  krytellan [ Mon Nov 28, 2011 9:57 am ]
Sorry, no. The adapter I need is the plastic one that actually attaches to the outside of the trans. It has a hole for the speedo cable to go through. I guess it's my mistake, it should probably be referred to as the housing as seen here:
http://www.transmissioncenter.net/speed ... ____va.htm
If you click on Dodge and Jeep you will see it the 6th item down. I'm sorry for my lack of proper identification.
Author:  Joshie225 [ Mon Nov 28, 2011 10:14 am ]
This one?
Author:  slantzilla [ Mon Nov 28, 2011 10:16 am ]
Sorry for all the mess, but after seeing a picture of what you want I do not have any of that kind. Mine are all for the screw on type cable. :cry:
I hate to say it, but I have never seen one of the plastic ones. :shock:
That is a cool site for parts and info. :D
Page 1 of 2 All times are UTC-07:00
