Vacuumn advance question for Dan
https://slantsix.org/forum/viewtopic.php?t=47103
Page 1 of 1
Author:  Sam Powell [ Sat Nov 26, 2011 5:29 am ]
Post subject:  Vacuumn advance question for Dan
Dan, In a recent post on a thread somewhere here you stated that a non-functioning vacuum advance would result in a single cylinder miss. Would you care to elaborate on that a bit please? Why does this happen?
Thanks, Sam
Author:  supton [ Sat Nov 26, 2011 6:18 am ]
IIRC it had everything to do with the vacuum advance being hooked up to the #6 intake manifold runner, in that particular case. Less to do with the ignition system, and more to do with a vacuum leak that only one cylinder sees.
Author:  wjajr [ Sat Nov 26, 2011 6:25 am ]
That was back in a post by "60 Plymouth": Low idle vacuum, sluggish throttle response, low power in Engine. He had a bad vacuum advance dashpot that was sucking air, and connected to a vacuum sorce in number 6 intake runner. The introduction of additional air into just one runner caused number six to run lean at idle due to low volume of air-fuel mixture flow.
Once engine was running faster than an idle the small amount of additional air added to number six became insignificant at higher rpm.
Author:  60 Plymouth [ Sat Nov 26, 2011 6:37 am ]
A lot of that was speculation before I'd got back to say what my setup was - my vacuum advance is hooked up to the port on the carb.
On an engine with everything else intact a leak in the #6 runner causes #6 cylinder to have a leaner A/F ratio. If your vacuum advance is hooked to ported vacuum then this cannot happen. I believe a leaky vacuum can would cause all cylinders to run lean (extra air being introduced at the carb instead of just one runner.
I believe the same problems can be found if you have leaky vacuum accessories hooked to the #6 runner though (power brakes, defoggers, central locking if you got the 'fancy pants' options on my car).
Author:  Sam Powell [ Sat Nov 26, 2011 6:53 am ]
Thanks. That is clear.
Sam
