Over drive bolt up
https://slantsix.org/forum/viewtopic.php?t=47132
Author:  Tinker67d100 [ Mon Nov 28, 2011 2:38 pm ]
Post subject:  Over drive bolt up
Hi will a 76 od trans bolt up to a 67 truck( case ) bell housing or will I need to use the 76 bell thanx
Author:  raPoM [ Mon Nov 28, 2011 2:41 pm ]
Not sure what trans you have now,but you will need to use a bell for a 833 o/d slant application because of the larger Input Bearing Retainer size on the 833 od.
Author:  Tinker67d100 [ Mon Nov 28, 2011 2:46 pm ]
Do know if there is a slave cyclyder to fit the 76 bell my ole truck has hydraulic clutch thanx
Author:  raPoM [ Mon Nov 28, 2011 2:57 pm ]
My 87 D100 has the 225/833 OD combo with a hydro clutch set up,maybe you could use the same parts?!
Author:  DusterIdiot [ Mon Nov 28, 2011 6:29 pm ]
Post subject:  Depends...
If he has an NP435 you'll need to make a bracket to make it work, the bellhousing and fork is different on that guy in the 60's vs. the version used in the 70's/80's. Also the 60's bell usually has the fork and slave cylinder bolted to the passenger side of the bellhousing...the 70's Manual Fork Np435 bell and the A-833OD bell have the fork on driver side of the bellhousing.
I think I have posted some pics of a few bellhousings a while back that you can do a search and see if it will work out for you.
Another question to ask, is your '67 tranny supported by a crossmember or does the bellhousing have a set of "ears and rubber isolators"?
Author:  Tinker67d100 [ Mon Nov 28, 2011 7:17 pm ]
Yes my clutch fork is on the passenger side , and the trans does not have a crossmember there mounts on each side of the bell houseing
Author:  DusterIdiot [ Mon Nov 28, 2011 7:30 pm ]
Post subject:  Fab time...
I think you could still make it all work, but something tells me you may need to break out the mig welder and some iron to make sure everything is secured properly, especially since the A-833 would have the tailshaft tranny support. I think the '67 should have some available frame nearby to make a crossmember hook up...(The good thing is the truck would be a few hundred pounds lighter after the swap...)
Author:  Tinker67d100 [ Mon Nov 28, 2011 7:49 pm ]
Ya i have all ready looked at that ,there are already holes in the frame, probably for the auto option ,I run a header ,I wonder if the Hydraulic slave on that side would get too warm
Author:  Rug_Trucker [ Tue Nov 29, 2011 9:25 am ]
Really? Got me wondering about locating some of these parts!
I would love to have a hydraulic in my Duster with the 833OD.
Author:  DusterIdiot [ Tue Nov 29, 2011 6:11 pm ]
Post subject:  Lol...
The stock truck setup in the 60's trucks are great at getting the firewood to your house and getting groceries...It will not win you any bonus time during the 1/4 mile two step shuffle...
FYI,
Author:  raPoM [ Tue Nov 29, 2011 6:17 pm ]
Rob-
I think he was talking about the hydro set up on my 87. I really like the pedal feel,its not as "jerky" as the old Z bar set up like I had on my old Dart Sport. My only beef is that its a closed system,and their is no easy way to bleed the system.
Jared
Author:  Tinker67d100 [ Wed Nov 30, 2011 3:07 am ]
Ya I agree with Jared ,I like the feel of the hydro over the z bar , that's why I was hoping to be able too stay with my current bell housing
Author:  Rug_Trucker [ Wed Nov 30, 2011 3:36 am ]
Rob-
Jared
Yep talking about the hydro set up.
