Choosing the Best Cam (Cummins Turbo 500 HP Slant)
https://slantsix.org/forum/viewtopic.php?t=47139
Page 1 of 5
Author:  MotoGrey [ Tue Nov 29, 2011 9:18 am ]
Post subject:  Choosing the Best Cam (Cummins Turbo 500 HP Slant)
Jeez, What does it take to get a response on simple straight forward build questions guys?
Hey Slanters,
After reading and gleaning all I am currently able to understand about camshaft selection I still need to defer to those more experienced than I.
Thinking the Oregon Cams #1333 reversed with LSA 106? is likely the right choice, here is my build:
1984 D-100 pickup Hydro Slant. Rebuilt to factory specs by Portland Engine Rebuilders.
GM HEI, Electronic Ignition.
Vacuum controlled Chrysler distributor.
Nos. Holley 2280 2BBL acquired from Dan.
Offy 4 BBL intake with adaptor.
Head shaved .100" or will be corrected to 9.0 to 9.25 to 1 compression
1.70 and 1.44 stainless valves. Pocket ported for easy breathing.
Hooker six into one header collecting next to motor mount at about pan gasket level. Ceramic coated for rust resistance. Has heat riser tube. 8)
2.5" single exhaust through free flow stainless cat then 2.25 for noise control.
904 torqueflight stock convertor.
3.23 open ( may decide to go to ltd slip later ) 9.25" rear.
215 70R15" tires
My goal is to achieve an efficient road vehicle with the torque necessary to carry 1000 lbs. High low end torque and 20 MPG Hwy is my goal. Yes we have hills in Oregon :) .
Thanking you in advance for kindly sharing ideas and experience regarding this build and camshaft choices. Ray
Author:  Rug_Trucker [ Tue Dec 06, 2011 6:07 pm ]
Turbo?
Author:  MotoGrey [ Tue Dec 06, 2011 7:21 pm ]
No Rug, no turbo. Just a standard build. It is just so amazing though how hard it is to get a thread going when it doesn't have a lot of pizzazz. Kind of a travesty really. Thank you for the response.
The question was just for a confirmation as to the can choice before I was in to deep in this rebuild.
Hmmmm, oh well. :)
Author:  ceej [ Tue Dec 06, 2011 7:36 pm ]
Hi Ray,
Your doing an hydraulic engine. The vast majority of slant six builders work with mechanicals cams. I've got a copy of OCG's mechanical profile sheet.
I don't have the cam specs for the 1333. If you have the cam card, or the hydaulic cam spreadsheet from OCG, scan it and share it.
I looked for it online, but OCG has changed their website. Couldn't find it to make an informed judgement on the profile.
Author:  raPoM [ Tue Dec 06, 2011 7:43 pm ]
Need the cam specs. But with a stock stall 727,3.23's,and a 27 inch tire,you arent going to have much wiggle room on the cam,go too big and it will be a dog off the line.
Author:  Reed [ Tue Dec 06, 2011 7:56 pm ]
If you can, trade the 727 for a 904 with the wide ratio gearset. Less parasitic power loss in the trans and better gears for acceleration.
Author:  ceej [ Tue Dec 06, 2011 8:00 pm ]
Post subject:  Well shoot. Found it.
http://www.oregoncamshaft.com/Hydraulic-Cam-Specs.html
Your RDP idea looks like a good cam for a stump puller. Not sure what it would act like up top.
Your rear gears seem a bit tall for the purpose. How fast do you need the truck to go? If 55 mph will do the trick, I'd shorten them up a bit.
Reed is right. The 727 is going to eat a bunch of your available power. You certainly aren't going to break it though. :D
Author:  Rug_Trucker [ Wed Dec 07, 2011 4:16 am ]
One thing to consider on the tranny is tail shaft length. Do they make 904 truck length slant trannys? I guess a B or E body one would work for the length.
V8 talk I put a 2200 stall in my van with the 360. No noticible MPG differences. It helps with the TN hills and all the weight. (5800lbs+!!) No shift kit. The builder removed 9 springs from a plate and left 3. Firm shifts.
When I build a slant from the ground up in the future? I want to start with a zero deck before figuring what to shave the head down to.
Get a vacuum gauge to work the pedal.
Author:  Dart270 [ Wed Dec 07, 2011 8:13 am ]
Sounds like a pretty well thought out combo to me. Sorry it took some grumpiness to get a response.
You can't just put an exh lobe on the intake (can't just swap INT/EXH specs on the 1333). Pick another INT lobe with correct specs and EXH lobe with correct specs. That cam should not be too big for a stock converter. Headwork and 9:1 will really wake this thing up, much more than the exact cam specs.
FYI, a stock Slant will do fine carrying 1000lbs and 20 MPG, and you'll be better off than stock. I packed my '68 Dart with 1000+lbs on many occasions (or pulled 1500lb trailer) with the stock motor and no worries.
Author:  Reed [ Wed Dec 07, 2011 9:58 am ]
I have swapped more transmission than I care to think about into my brother's 83 van. 727s and 904s. The 727 is several inches longer than the 904 and requires a different front yoke due to spline differences on the output shaft. However, many many many (in fact MOST) 80s era Dodge trucks and vans that had a slant six were built with a 904T. So just grab the driveshaft and transmission out of the same donor truck.
Author:  Dart270 [ Wed Dec 07, 2011 10:09 am ]
If you have a 727 and it works and has been in the truck, I would just use that. I think the power loss is not enough to rework everything for your application.
Author:  Reed [ Wed Dec 07, 2011 10:43 am ]
I must respectfully disagree. If max fuel economy and towing ability is the goal, then it is worth it to switch to a wide ratio 904. I recall seeing figures years ago that indicated that the 727 uses something like 15% more horsepower to work than the 904 in addition to being significantly heavier. The wide ratio gearset is also better for getting a big heavy vehicle moving. I know in my brother's van that switching from a 727 to a 904 and then a 904T improved performance and economy.
However, your budget and desire to swap parts will decide if it is worth it to you to switch transmissions.
Author:  exoJjL [ Wed Dec 07, 2011 2:01 pm ]
I absolutely believe it, and may actually be higher than 15%. I read figures stating going from close ratio (ie 3.7:1) to 2.7:1 yields up to or around a 5mpg increase.
Author:  MotoGrey [ Wed Dec 07, 2011 2:46 pm ]
Post subject:  Oregon Cam grinding Hydro Cam Specs
Here is the link to Oregon Cam Grinding Hydraulic specs.
I have been following the DadTruck thread Here
http://slantsix.org/forum/viewtopic.php ... 4758adefcd
Maybe the 1527 would be better, but I don't see the specs for it.
Author:  ceej [ Wed Dec 07, 2011 4:49 pm ]
A bit more lift wouldn't be bad, but you'll have to decide that. I'd do it to take advantage of the oversize valves.
Edited 'cause I just repeated something someone else said above. :roll:
Page 1 of 5 All times are UTC-08:00
