It is currently Thu Jun 18, 2026 2:09 pm
 Post subject: Moog part numbers
PostPosted: Thu Nov 24, 2011 10:47 pm
Car Model: 1963 Dodge Dart convertible
I found a upper ball joint part #MOOG-K704 that was listed as fitting my 63 Dodge Dart. I found this part on Amazon for $20 cheaper but their website says it will not fit my 63.
Anyone know if this will or will not fit and if there is a list of Moog parts for the 63 Dart?
Thanks in advance,
John
Psychics will soon lead dogs to your body!
1963 Dodge Dart 270 convertible
PostPosted: Thu Nov 24, 2011 10:57 pm
Amazon's part application catalogue isn't worth looking at—it's not even partially complete and it's full of errors. K704 is correct for your '63.
PostPosted: Fri Nov 25, 2011 9:05 am
Is it worth ordering to save 30% as long as the parts are the same? From what I have found I can save a couple of hundred bucks over ordering the front end parts elsewhere, tie rod ends, ball joints, idler arm, pitman arm, bushings, etc.
Thanks
