| Hella Center Brake Light Application Over Rear Defrost Grid https://slantsix.org/forum/viewtopic.php?t=47168 |
| Author: | DonPal [ Fri Dec 02, 2011 4:35 am ] |
| Post subject: | Hella Center Brake Light Application Over Rear Defrost Grid |
Can the Hella Center 3rd Brake Light that adheres to a back window be placed over a retrofit defroster grid? Has anyone tried this? Dan Sterns lighting website links don't seem to work to get this answer or purchase this item? |
| Author: | SlantSixDan [ Fri Dec 02, 2011 9:11 am ] |
Dan Stern is right here. I get dozens of emails a day from the site, but it sounds like it's not working for you; what happens when you try to click a "Mail me?" link? There is no problem installing the Hella central brake light kit over OE or retrofit defogger grid lines. |
| Author: | DonPal [ Fri Dec 02, 2011 9:39 am ] |
Quote: it sounds like it's not working for you; what happens when you try to click a "Mail me?" link?
The site I'm visiting is www.danielsternlighting.com and the link says "E-mail me your query"The pop up says "could not perform the operation because the default mail client is not properly installed" Haven't seen that occur with any other link...ever. |
| Author: | SlantSixDan [ Fri Dec 02, 2011 9:49 am ] |
Weird. There's nothing unusual about the code for the mail link, it's a perfectly ordinary, standard HTML mailto link. It sounds like an issue with your email program. In any event, send the mail to me manually: tech@danielsternlighting.com . |
| Author: | DonPal [ Tue Jan 03, 2012 6:46 am ] |
| Post subject: | 3rd Brakelight Installation In 65 Dart Over Defroster Grid |
See picture of the installation steps & comparision between brakelight intensities at night & during the day. http://www.flickr.com/photos/donpal/662 ... hotostream The Hella brakelight is assembled at the factory with the wiring coming out the top.....I disassembled the Hella & rerouted the wire internally so that it came out the bottom........ it was less visible & neatly dropped straight into the trunk. |
| Author: | SlantSixDan [ Tue Jan 03, 2012 8:36 am ] |
Nice, clean installation! |
| Author: | Danarchy [ Tue Jan 03, 2012 2:41 pm ] |
Deluxe 3rd tailight, I need to get one of those! |
| Author: | SlantSixDan [ Tue Jan 03, 2012 5:31 pm ] |
Quote: Deluxe 3rd tailight, I need to get one of those!
They're on mah website here and reviewed here.
