| i need rockers https://slantsix.org/forum/viewtopic.php?t=47176 |
| Author: | kielbasa [ Fri Dec 02, 2011 2:18 pm ] |
| Post subject: | i need rockers |
if anyone has a good bitchen set of rockers, where everything still fits tight, and is willing to sell them, i need a set. if not, is it even worth looking in the junkyard and pulling them all off untill i find a good set, or are they usually all bad. i tried using the vice trick to pinch them tight for the adjuster, but i can either not pinch it enough, or it cracks the rocker... i feel this tecniuqe is $#!+. i should have just left the jam nuts on there :\ |
| Author: | 65CrewCabPW [ Fri Dec 02, 2011 8:07 pm ] |
My local parts house said they had a machine shop that would sell me a rebuilt rocker arm assembly (includes all rockers, locknuts, etc) for around 75 bucks. Try Oregon Camshaft as well, as I seem to recall they had assemblies too. Used ones are ok, if they're not destroyed (they tend to be good or destroyed, not much in between). I now have many locknuts on mine and probably will eventually find all the adjusters locknutted... |
| Author: | kielbasa [ Fri Dec 02, 2011 8:55 pm ] |
I just wanted mine to fit tight, so I could adjust them all while car is running, then shut car off, and lock nut them all |
